Absolutely! You may have not been getting the fuel injection controller out of the enriched mode, and more of the fuel will be vaporized.
Agreed. I'll bet your old thermo wasn't opening fully, hence the reduced operating temp. Thermos are a PITA in that they can fail partially and be problematic in operating only marginally. You probably didn't have much heat from the heater in the interior either, if you noticed.
