Old 12-10-2009, 09:40 PM   #54 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
If you get around to testing and do A-B-A runs,with and without the tail,consider adding ballast to the van equal to the weight of the tail when you run without it.
That's easy. I'll just put it into the back of the van.
Considering aerodynamics, orange4boy, have you noticed if you get better mileage at high altitudes?
I have heard of this effect but have not been on a trip high enough to see. I know high altitude is better for aircraft FE. Must be for the same reasons: lower drag from thinner air = higher ground speed per engine revolution. You will read the same airspeed but have higher ground speed. The lean burn is also true if your engine can't compensate. I remember having to re-lean the engine after an altitude change.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
