Old 12-11-2009, 01:09 AM   #326 (permalink)
MetroMPG
90 day: 57.73 mpg (US)
Originally Posted by TheSGC View Post
You should insulate the batteries. I got a sheet of 1" blue insulation board from Home Depot to insulate my batteries, and it made a HUGE difference.
This is the curse of an EV that doesn't get used regularly when it's cold out. Even with insulation, the batteries will go cold after a day or 2. I need heat too.
Paul: you use yours more. Give it a try!
