Old 12-11-2009, 03:41 PM   #131 (permalink)
Weather Spotter
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
I went out and bout some pizza pans at Walmart $3.97 each.
I am trying to figure out how to mount them to my wheels.
here is my current wheel:
here is my one tire that is missing it's hub cap (why I am trying this mod):
From what I have read there are several options:
1. modify a center cap (bolt, nut & epoxy) - not an option for me.
2. modify a cheep set of hub caps (pop on and off) - could work but would require buying a set of hubcaps to mod.
3. drilling and taping the rim then bolting on the pizza pans - could work but I am not sure where to drill them. also I worry that drilling would reduce the strength of the rims/ off balance them. ideas?
4. zip tie the pizza pans on to the rim - could work but would reduce the looks and MPG gain.
5. magnets - have not heard any feedback on this idea but sounds risky.
What is your idea of a Matrix with pizza pan hub caps?
What would you suggest I use for mounting?
Why?
Last edited by Weather Spotter; 12-11-2009 at 03:50 PM.. Reason: add pic of wheel with hub cap
