Old 12-11-2009, 04:05 PM   #119 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
So the heater core and engine block share a circuit and the rad is separated from that by the tstat. I forgot about that. So the inline coolant heater can circulate (by convection) the coolant thru the block with the tstat closed. Potentially much better pre heat than a block heater especially for the cabin air.
FYI, there is an electric pump in the NHW11 heater core loop.
Could there be a sweet hack here using the existing inline coolant pump and a passive inline heater to really warm the engine/heater core loop? This would be much better/cheaper than relying on the convection of the tank pump's bypass system.
I'm feeling warmer already...
Thoughts?
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
