Old 12-11-2009, 05:37 PM   #58 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
Ah. lower pumping losses with respect to the compression ratio. That makes sense. I'm not an expert on this stuff by any means, especially when boost is added to the mix.
I suppose running at a certain amount of boost could cause the system to enrichen the mixture and possibly reduce the amount of spark advance to prevent predetonation. (Maybe water injection could help with that.)
I found a great article on home brewed water injection using a cold start injector which the Previa already has. Mine is disconnected with no ill effect. Could easily be modded to be a water injector.Found here along with some other great Toyota tips (see his signature)Cheap water injection. The "free" mod series. Also see his thread on cheap A/F mixture monitoring.
Also for the Previa, have you seen my thread on TCC lockup switch?http://ecomodder.com/forum/showthrea...tch-10028.html
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
The Following User Says Thank You to orange4boy For This Useful Post:
AlaricD (12-11-2009)
