Old 12-12-2009, 02:26 AM   #125 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
Did you go in from the bottom?
Yes. I had the car on jacks for the aborted block heater install. The plastic covers are held on by just a few screws. I had not put them all back in anticipation of more work underneath. It's fairly easy to pop off the screen from there.
I'm interested in the pattern if you can take a photo including a ruler or outer dimensions before final fitting.
Will do.
I also adjusted the headlights tonight. not too big a deal.
The coolant tank (pops upward off the metal bracket) and intake snorkel (body clip) have to come off the left side to get at the 8mm nut.
The windshield washer fluid fill tube has to come off the right side (one clip). It's a tight fit on the right side but taking out the washer fluid tank is too much work.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
