In fact, according to these tests Higher inflation pressure reduced stopping distance and increased coefficient of friction...Scroll down for stopping distances.
FEA chapter III. tire pressure survey and test results
Unfortunately, higher pressures were not tested.
These data indicate that stopping distance is longer with lower psi for every case except for two cases with the full depth tread with ABS on the Dodge Caravan.
(Poor Cara. Sorry Christ)
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
