Old 12-14-2009, 09:45 PM   #18 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
Oh, for sure, off road is a different animal. There you often want to increase contact patch so you don't sink or so the tire can cover medium size bumps and not get stuck between two peaks of a rock, for instance.
On ice, you want a cold tire. The minute you spin and heat up the tire you lose most of your traction.
With chains, lower pressure so the car does not vibrate excessively.
"Except in aquaplaning", is a huge caveat. When you are sliding on ice, snow, or slush, you are actually hydroplaning.
I think most people think of aqua planing as on a hard surface with liquid water. To slide on ice there does not have to be a liquid layer, but there often is.
There are a lot of "it depends" when it comes to tire traction and pressure. The best would be a variable pressure system. I think the Porsche 959 had this.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
