Old 12-14-2009, 09:47 PM   #70 (permalink)
some_other_dave
Note that header wrap is much better at holding moisture against the exhaust pipes than air is. Mild steel (or cast iron!) exhaust parts tend to rust significantly when wrapped. Might be worth checking that your exhaust is made from stainless if you want to do that.
-soD
