Old 12-14-2009, 11:04 PM   #17 (permalink)
winkosmosis
Originally Posted by Christ View Post
thatguitarguy -
I made a suggestion to someone else about this same topic, actually. You can put screws though your lug nuts from the insides. The chrome caps are very thin, and easy to drill through. Plus, the studs don't screw in that far.
Alternatively, you could just thread screws through the chrome, as well. I'd rather at least have a nut JB-welded into the caps, though.
Those lug nut covers fall off, so I doubt they will hold a pizza pan.
I think it makes more sense to just use long lug nuts that leave unused treads at the top, and screw the correct tread bolt into them, effectively extending the lugs. Then you can bolt on the pan with nuts.
I googled and found these open end lug nuts
http://www.ravspeconline.com/shop/ca...th=198_582_583
The Following User Says Thank You to winkosmosis For This Useful Post:
k.civic.f4i (01-13-2010)
