Old 12-14-2009, 09:32 PM   #11 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
No offense, but isn't that just a little over engineered?
Old 12-14-2009, 09:40 PM   #12 (permalink)
Maroon Ballon - '98 Chrysler Town & Country LXI
90 day: 26.42 mpg (US)
MaEsTRO - '95 Geo Metro 5spd hatch, 3 cyl
It's the same principle as tire chains. Do you think these are over engineered?
I've had to change tires in the dark, in the middle of a blizzard, in sub-freezing weather, more than once. Needing to have extra tools to unscrew a hubcap that is bolted somehow to the wheel, or trying to break a caulk bead with a credit card, when your hands are freezing, is not feasible.
Old 12-14-2009, 09:43 PM   #13 (permalink)
epic stock master
luvit's Avatar
86 Accord LX (carb) - '86 Honda Accord LX
90 day: 35.57 mpg (US)
caulk bead w/ credit card = 4 seconds.
put some gloves in your glove box?
single person car thread
Old 12-14-2009, 09:45 PM   #14 (permalink)
I can tell you've never done it.
Old 12-14-2009, 09:46 PM   #15 (permalink)
epic stock master
luvit's Avatar
lived in ND for 2 winters... been there.
Old 12-14-2009, 09:54 PM   #16 (permalink)
And you've glued your hubcaps to your wheels and removed them with a credit card in sub-freezing temperature? I'm calling BS on this one.
Old 12-14-2009, 10:04 PM   #17 (permalink)
Originally Posted by Christ View Post
thatguitarguy -
I made a suggestion to someone else about this same topic, actually. You can put screws though your lug nuts from the insides. The chrome caps are very thin, and easy to drill through. Plus, the studs don't screw in that far.
Alternatively, you could just thread screws through the chrome, as well. I'd rather at least have a nut JB-welded into the caps, though.
Those lug nut covers fall off, so I doubt they will hold a pizza pan.
I think it makes more sense to just use long lug nuts that leave unused treads at the top, and screw the correct tread bolt into them, effectively extending the lugs. Then you can bolt on the pan with nuts.
I googled and found these open end lug nuts
http://www.ravspeconline.com/shop/ca...th=198_582_583
The Following User Says Thank You to winkosmosis For This Useful Post:
k.civic.f4i (01-13-2010)
Old 12-14-2009, 10:12 PM   #18 (permalink)
- - '10 Toyota Prius III w/Navi
Hi GuitarGuy,
Driving down long grades makes the use of flush hubcaps an issue with regards to brake temperatures. So, my comment was on-topic...
Old 12-14-2009, 10:45 PM   #19 (permalink)
The pan-caps won't be flush, but they will close off airflow from the outside. Most of the air for brake cooling comes from the inside, where the brakes are, but I see your point. I use engine braking a lot, and have never had trouble with hot brakes, but the smell of overheated truck brakes is very common in the mountains. My van has an electric trailer brake, and if I'm going to do towing I would most likely be prepping my vehicle differently by removing the pan-caps and the grill block. This is why I'm trying to do modifications that are more modular and easily removable. If I have to load the van down, I don't want to spend hours reversing aerodynamic modifications.
Old 12-14-2009, 10:46 PM   #20 (permalink)
The Geo - '93 Geo Metro
90 day: 45.16 mpg (US)
3m auto tape worked for me, but the cold you get is different than what I get.
Honda Fit Belly Pan Project Fit Aerodynamics 17 08-10-2015 08:29 AM
Where to get a 15" stainless or aluminum pizza pan? Chris D. DIY / How-to 12 12-14-2009 09:58 PM
Pizza pan wheel covers - smooth or perforated? jabb Aerodynamics 5 06-23-2009 09:01 PM
pizza pan - dish in or out? lightning Aerodynamics 14 06-07-2009 12:26 AM
Pruis Pizza Pan Hub Caps.... justpassntime Aerodynamics 1 07-14-2008 09:55 AM
