I forgot to add one technique I use. There is one small hill, maybe 50’ to 75’ elevation right after a narrow 2 lane bridge on a back road. After the initial steep part it slowly gains elevation for about 0.4 of a mile. I have found that powering up the initial steep section to gain speed to 50 mph (psl 45 mph) will net me greater overall mileage (read: less of a loss) than gliding to the base and DWL up the entire section at 45 mph. I’m assuming it has to do with my engine BSFC chart and finding the right rpm/mph combination for the climb. Unfortunately this is the only section of my commute that I have found this technique works on.
Bottom line, try different ways of approaching hills and see if there is a combination of rpm/mph/gear that works best.
