Old 12-16-2009, 02:20 PM   #56 (permalink)
HFRex510
Im also going with this swap, but didnt get the ecu. Currently running the d16y8. I know the y8 single vtec pressure switch fits on the d15b head. Might try to see if that will run fine. Wish i had the P2J-003. Anyways if you dont want to bother with making your own wire harness, here is a good company to call.Rywire.com. Tell them your setup and they will make up a plug n play harness for you. Good Luck on the project and I hope you save gallons!
