Old 12-17-2009, 05:35 PM   #41 (permalink)
bgd73
oldscoob - '87 subaru wagon gl/dr
90 day: 47.06 mpg (US)
a mainers point of view...
you know when its cold when you got a heater for the heater.
you know when its cold when the top third of the warm room is a phosphourescent white fog.
you know when it is cold when you jimmy rig plastic covers to fill in the electrical outlets....6 feet away is not enough to stop the frigid hurricane coming out of them.
..."r13" is for polar bears.
..when you leave the house you have all your teeth, when you finally warm up again, an epiphany a few went missing.
..spitting blood after the same simple adventure, outside work to in...
... The car radiator air dam suffocates the thin air to the point of no heat anyway...let it have it.
... tires pounce thier way to flat after a WOT run.
... gas shrinks. check the tank for leaks anyway.
...when the french fries you ate in the car in january, decide to return a fresh odor in june...
..the pc power saving "slow mode" is an overclock as well.
