Old 12-17-2009, 04:35 PM   #41 (permalink)
oldscoob - '87 subaru wagon gl/dr
90 day: 47.06 mpg (US)
a mainers point of view...
you know when its cold when you got a heater for the heater.
you know when its cold when the top third of the warm room is a phosphourescent white fog.
you know when it is cold when you jimmy rig plastic covers to fill in the electrical outlets....6 feet away is not enough to stop the frigid hurricane coming out of them.
..."r13" is for polar bears.
..when you leave the house you have all your teeth, when you finally warm up again, an epiphany a few went missing.
..spitting blood after the same simple adventure, outside work to in...
... The car radiator air dam suffocates the thin air to the point of no heat anyway...let it have it.
... tires pounce thier way to flat after a WOT run.
... gas shrinks. check the tank for leaks anyway.
...when the french fries you ate in the car in january, decide to return a fresh odor in june...
..the pc power saving "slow mode" is an overclock as well.
Old 01-01-2010, 03:20 PM   #42 (permalink)
When you spit, and it freezes before it hits the ground. Kinda makes a cracking sound, and sounds like sleet when it hits.
This happens at about 40 below zero.
'Course, no one with common sense would actually want to test this...
Old 01-03-2010, 12:55 PM   #43 (permalink)
...a WRT54G V3 runs stable at its maximum power setting of 251mW... (Going below freezing will do that. Still need to up the voltage to get a good signal, though.)
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
Old 01-04-2010, 09:32 AM   #44 (permalink)
38 time NHRA/IHRA Champ
ATaylorRacing's Avatar
This is no joke....when I was a mail man it would get so cold IN THE MAIL TRUCKS, that my coffee would freeze in my drink holder on the dash and when I pulled rubber bands off of the bundled mail they would not regain their shape...just look like strung out thing noodles! Their huge windows would not help matters at all. They also have aluminum radiators so they don't overheat in the summer...great for race cars, but sucks in the winter. In the summer on a 80 degree day the interiors would hit over 150 degrees using the temp gauges that I use at the drag strip...in the shade too!
Just think of how cold it could be if we did not have global warming.......he said tongue in cheek!
42 time NHRA/IHRA drag race champ
05 SRT4-12.17@117 mph on DOTs-31.0 mpg-SOLD
96 Geo Metro-3 banger-60.1 mpg-SOLD
95 BMW M3-13.41 @ 106 mph-31mpg-SOLD
77 Chevy Monza with 350/350-FOR SALE
84 Horizon-1880 lbs-29 mpg
95 Neon-43 mpg
99 Z28-10.80 @ 127 mph-27.1mpg
2011 Prius-62.1 wife's
Old 01-07-2010, 06:26 PM   #45 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
You know it's cold when your utility company has rolling black outs due to cold weather.
You know it's cold when you spend 2 days covering + heating Orange trees.
You know it's cold out when polyester gelcoat hardens like a rock without ever opening the can.
You know it's cold out when lacquer flows like Molasses.
You know it's cold out when your Whatt's Up Indicates that your car battery has an effective capacity of 10 Amp hours and battery only has 4 volts left after test. Well, Ok that battery was toast anyways.
You know it's cold when even though you are an EcoModder you consider going out and starting your TDI just to see if it will start.
You know it's cold out when you are running strait Diesel for the second tank this year.
Mine run stable at 251 No problem, the receive sensitivity goes in the toilet . . .
But then again I do have North bridge heat sinks on mine though.
How do you increase the voltage on the radios?
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 01-07-2010, 09:43 PM   #46 (permalink)
Reconnect the output circuit to its own voltage regulator. The official specification lists the maximum operating voltage for the chipset is 3.6v. The regulator (LDO from the 5v supply) I put in will go up to about 4v. For the record, it was set as high as it goes and it survived the tests. I'm sure it will degrade much faster than stock, but that's generally true of any serious overclocking.
Old 01-18-2010, 09:05 AM   #47 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
True story from last week's hiking trip.
You know it's cold when...
...You're hiking in the mountains. Snow, very cold. Two hikers:
- I think my boot may be a little too loose.
- Why don't you tighten it?
- The laces are frozen stiff.
Old 01-30-2010, 09:51 PM   #48 (permalink)
A few more I forgot...at least, I may have posted, can't remember.
you know when its cold when..
* you need teeth protectors and ear plugs to keep safe from the noise of studded snow treads at 18 below and 75 mph...
* when you look out the window to the perfect sound you hear vividly, a truck close by... but the highway is over a mile away...
* at 3am jump up suffocating to the cold draft that got into your lung...like a cat to a babies face...in your nice warm room.
This year has been freaky warm for maine. Barely below zero for a few nights.
Above is clayton lake, I monitor that more than the weather forecast. They get bangor wrong wrong wrong always warmer than it isn't or vice versa....it is horrifying how wrong they get it sometimes.
I hope to get at least a one night 15 below, got some welds that need immortalized.
Old 01-30-2010, 10:14 PM   #49 (permalink)
Driving the TurboWeasel
You know it's cold here when the rain hitting your car freezes to ice while you're driving. In Buffalo, NY (used to live there) that was normal. Here in SC, it's doomsday. Whatever, unlike everybody else equipped with a credit card, there's a giant ice scraper in my Buick's trunk.
2012 Chevrolet Cruze Eco 6MT
Old 01-30-2010, 11:52 PM   #50 (permalink)
Just cruisin’ along
jcp123's Avatar
Beater Echo - '00 Toyota Echo
90 day: 42.67 mpg (US)
Hondizzle - '97 Honda Civic DX
90 day: 46.55 mpg (US)
Shaggin Waggin - '14 Chrysler Town + Country
90 day: 22.56 mpg (US)
I'm from California. What's this "cold" of which you speak?
Oh, it did snow today. Lightly.
'97 Honda Civic DX Coupe 5MT - dead 2/23
'00 Echo - dead 2/17
'14 Chrysler Town + Country - My DD, for now
'67 Mustang Convertible - gone 1/17
Cold air VS Warm Air Intakes - what's the difference? deadman1474 EcoModding Central 63 03-22-2019 09:53 AM
Disconnected Idle Air Control - for lower RPM after a cold start Lazarus EcoModding Central 19 04-15-2011 03:50 PM
Winter cold start & idling warm-up experiment MetroMPG Hypermiling / EcoDriver's Ed 17 12-17-2010 03:39 PM
MetroMPG.com mailbag: Metro engine won't stay warm in super cold weather MetroMPG General Efficiency Discussion 13 02-01-2008 11:28 PM
You know it's REAL cold when... Peakster The Lounge 13 01-22-2008 02:23 PM
