Old 12-17-2009, 11:49 PM   #13 (permalink)
dremd
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
Originally Posted by Christ View Post
That's why they make chokes.
Design the engine to run efficiently at high alt, and at low alt, it'll probably blow up, so you either set it up to only use a max amount of fuel, which is pig-rich at low alt, and perfect at high alt, or you set it up with a choke, so that it runs as a smaller displacement engine (effective displacement) at low alt, and runs "normally" at high alt.
I hate making these post.
That is the beauty of a Diesel engine, runs good from 500:1 - 10:1 AFR
Choke on a diesel is useless. Advance injection timing for cold starts.MKI VW diesels had a lever to advance pump for cold starts.
Best way to adjust effective displacement is with forced induction, turbo would be easiest IMO. Just have to keep cylinder pressures acceptable at takeoff power to maintain durability.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
