12-17-2009, 03:29 PM
Fuel economy in the air (diesel airplanes?)
So I was reading the thread I can no longer find a while ago, and the thought has been roiling around in my mind since... Most prop planes are spark-ignition, aren't they?
Has anyone ever built a diesel prop plane?
12-17-2009, 03:40 PM
Moderate your Moderation.
Pasta - '96 Volkswagen Passat TDi 90 day: 45.22 mpg (US)
Good question. I'm intrigued. (Actually, I'm Christ. Intrigued is another member.) Nonetheless, I'm interested to see what kind of information gets dragged up in this thread.
The Following User Says Thank You to Christ For This Useful Post:
12-17-2009, 04:17 PM
...beats walking...
...yes, diesel engines were used a lot during the 1920's-1930's:
http://74.125.155.132/search?q=cache...&ct=clnk&gl=us
...on a similar note -- I'd like to know "why?" EPA-fuel economy "guidelines" haven't also been applied (shoved up?) to the aircraft industry yet?
12-17-2009, 04:20 PM
i have to imagine diesels are somewhat differently affected by altitude since their compression ratio is much more critical to combustion
Work From Home mod has saved more fuel than everything else put together.
12-17-2009, 08:08 PM
What better excuse can there be to put a turbo on an engine. Although I was thinking in terms of a <10,000ft. type of plane.
12-17-2009, 09:39 PM
Intermediate EcoDriver
The German Junkers bombers of WWII were diesel-powered.
Fuel economy is nice, but sometimes I just gotta put the spurs to my pony!
Originally Posted by thatguitarguy
Just 'cuz you can't do it, don't mean it can't be done...
Originally Posted by elhigh
The presence of traffic is the single most complicating factor of hypermiling. I know what I'm going to do, it's contending with whatever the hell all these other people are going to do that makes things hard.
12-17-2009, 09:42 PM
That's why they make chokes.
Design the engine to run efficiently at high alt, and at low alt, it'll probably blow up, so you either set it up to only use a max amount of fuel, which is pig-rich at low alt, and perfect at high alt, or you set it up with a choke, so that it runs as a smaller displacement engine (effective displacement) at low alt, and runs "normally" at high alt.
12-17-2009, 09:44 PM
...beats walking...
...uh, guys, two words: turbocharger and wastegate
...turbo's were usually used on ALL high-altitude engines, especially fighters.
12-17-2009, 09:59 PM
#9 (permalink)
IIRC the main concern is fuel gelling and emergency air restarts, they see some real cold conditions.
12-17-2009, 10:41 PM
#10 (permalink)
needs more cowbell
theres a couple hits for diesel airplane on youtube
(mentions Vulcan Diesel at 3:50 )
