Old 12-18-2009, 05:24 PM   #34 (permalink)
AlaricD
1995 Previa LE S/C Driver
Originally Posted by orange4boy View Post
Some manufacturers are using "smart charging" charge as much as possible when decelerating, and at the most efficient times.
Probably not implemented on the '95 Previa...
I could wire it with the brake light switch-- so when I'm braking, it will activate the alternator.
Granted, that could be somewhat counterproductive when stopped at a light, since the brake pedal is usually held for that. But when letting off the brake and leaving the stoplight, the alternator won't interfere with acceleration.
