Old 12-18-2009, 08:26 PM   #4 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Yeah, whatever you do, you'll need to grind/file it.
Or, you could try to JB-weld another screw to it, that might work too, but not likely.
I personally suggest flat file, then center punch, then small forward drill, then extractor.
If it's large enough, you could also try filing a slot into it with a cut-off wheel, then using a screwdriver. However, if it's in there tight enough that it broke off, a screwdriver will probably just strip the new slot out.
