Old 12-18-2009, 05:29 PM   #1 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
Steel screw broken off in aluminium throttle body
The head broke off, and only ~3mm of threads are sticking out. I can't get vise grips on that. I tried a drill, but the drill just wants to walk.
What are my options for removing this broken fastener?
Old 12-18-2009, 05:46 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
You could grind it flat, tap it with a nail, and try to get the drill started?
The Following User Says Thank You to SVOboy For This Useful Post:
RobertSmalls (12-18-2009)
Old 12-18-2009, 06:19 PM   #3 (permalink)
Big Salsa - '04 Toyota Sienna LE
Silver - '10 Toyota Prius III
This is the type of set that comes to mind... Screw-Out Set, SEARS Bolt-Out Set, SEARS although they might want to "walk" on you too if you don't use a punch to start the hole.
Old 12-18-2009, 07:26 PM   #4 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Yeah, whatever you do, you'll need to grind/file it.
Or, you could try to JB-weld another screw to it, that might work too, but not likely.
I personally suggest flat file, then center punch, then small forward drill, then extractor.
If it's large enough, you could also try filing a slot into it with a cut-off wheel, then using a screwdriver. However, if it's in there tight enough that it broke off, a screwdriver will probably just strip the new slot out.
Old 12-18-2009, 07:44 PM   #5 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
cut a slot w/a dremel in it and put a big screwdriver to it?
Old 12-18-2009, 08:00 PM   #6 (permalink)
Hm... Apparently, my edit didn't save.
I had also suggested what dcb said.
Old 12-18-2009, 09:09 PM   #7 (permalink)
Done a few hundred of those. I doubt if a screwdriver will do you any good.
Best bet is to center punch the shaft of the screw and drill through it. You will need a good cobalt bit.
Also probably need a easy out. Some of them are straight and you can actually get the screw to go in a small amount, like a 1/4 turn. Then back it out a little and run it back in a little to break the bond.
Be real patient and you might save the threads, some penetrating oil will also help.
Used to have to do a lot of them on broken manifold studs on the old in line 6 Nissan Z car engines. If you can't get it out measure the diameter of the screw you got out and use a drill bit just slightly smaller than that diameter. Sometimes this will allow you to get the rest of the threads out of the part you don't want to damage.
If not then you will have to use a helicoil.
regards
Mech
Old 12-18-2009, 10:30 PM   #8 (permalink)
Send a message via MSN to TempoRacer
Get a mig weldder and weld a nice big nipple of steel on the end of it then use some vise grips to take it off if vise grips don't work weld a nut on your weldded steel nipple then just use a socket and voila it out. I do over 20 a week in A Midas Muffler shop I'M a pro at it . so I know what to do. any question just ask.
Old 12-18-2009, 10:39 PM   #9 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
If there is still some extruding out, they make really nice extractors that will grab and remove the stud.
GeoMetroforum.com - got mpg?
Old 12-19-2009, 12:45 PM   #10 (permalink)
Left Lane Ecodriver
I ground it flat with a dremel, then tried to center-punch it with a nail. Not a chance. It blunted my best nails.
That's the point when I gave up, and replaced the throttle body as a unit. I was avoiding that because I didn't want to break the throttle cable adjustment screw. No worries there, because that screw is brass.
Job's done, Insight's got an IACV now.
I had to steal screws off my bicycle because I didn't have any other M5x0.9 bolts that were long enough.
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
DIY Throttle Body Spacer Coyote X DIY / How-to 51 09-13-2013 06:43 PM
Big Bore throttle body for MPG? cfg83 EcoModding Central 19 12-31-2008 09:44 PM
Archimedes screw throttle ronarprfct EcoModding Central 29 08-27-2008 03:10 PM
Throttle sensitivity Formula413 EcoModding Central 13 05-29-2008 04:55 PM
