Old 12-22-2009, 05:33 PM   #15 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Originally Posted by NiHaoMike View Post
I once put together a simple circuit to check the capacity of rechargeable AA batteries. I had a single transistor and two resistors as a voltage detector along with a switchable current sink (two transistors and two resistors) and a relay to connect a charger. I had the circuit connected to the RS-232 port on my PC (two output lines controlling the relay and current sink, one input line checking the voltage detector). I wrote a simple Java program to first connect the charger for a few hours, then disconnect the charger and connect the current sink while polling the voltage detector every few seconds. It then calculates the capacity once the discharge is complete.
I wish my definition of "simple" matched yours! This is something I would have to invest a big pile of time & learning to accomplish (not that there's anything wrong with that).
Though I will say: thanks, because your post motivated me to decide I will study electronics a bit more this winter.
