Old 12-22-2009, 09:18 PM   #473 (permalink)
SVOboy
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Two possible banjo adapters have been found.
One for use without FPR: Russell 640913 Russell Fuel Fittings for Honda Civic
One for use with: Russell 640920 Russell Fuel Fittings for Honda Civic
The FPR is the little dealy that sits on the fuel rail with a vacuum line, right? If so, I want the one without. However, both product images show it with that uneven crush washer, which as I recall goes with the non-FPR fuel rails and the banjo fittings with uneven sized openings, which mine is not.
Should I go ahead and buy assuming it's just bad stock photo use or should I be wary?
Basically, I don't want to get the wrong one and end up stranded with fuel spraying everywhere.
