Old 03-18-2008, 10:47 PM   #18 (permalink)
friedlbug
JadeAccent - '01 Hyundai Accent GL
90 day: 35.06 mpg (US)
Sonata - '11 Hyundai Sonata Hybrid base
90 day: 35.48 mpg (US)
Originally Posted by sharp21 View Post
I believe its set up so that the 24v gives you the acceleration/cruising, while the 12v is switched on for regen when going down hills.
Correct me if im wrong
S.
That's basically it. The only thing I'd add is a 12V step in acceleration from a pedal start, assuming it has anything to add running at 12V.
Hammer, my point about the switch rating is that I'll be a little under the current rating and twice the voltage rating. I'll test it thoroughly first.
Also, I thought of a problem with using the center off DPDT switch configured like the schematic above: The charging socket won't work - it'll just spin the motor. There has to be a switch to take the motor out of the circuit. Back to two switches.
