Originally Posted by SVOboy
UPDATES!
JOY!!!
Okay, before the updates actually happen, something more important.
QUESTIONS!!!
Knew there was a catch...
The guy is using 90 degree bends to prevent the hardline/fuel rail from having to support the weight of the fuel filter. Is this necessary? 3 of those damn 90* bends cost ~40 bucks on their own, and I'd rather avoid spending that if I don't need to. Though to be fair, it's only ~25$ more than my plan with the normal fittings.
Thoughts? Input? Thanks! Would like to order this junk tonight since I'm moving fast towards finishing this troublesome project
I would forego the 90 degree bends if possible. The fewer components, the fewer the problems,
usually. If you just rig up a small bracket system without the 90s, it will only be slightly more difficult to change the fuel filter and save you some green. Good luck!
