Old 12-23-2009, 08:33 PM   #92 (permalink)
winkosmosis
Originally Posted by dremd View Post
Not sure why everyone doubts such basic physics.
Easy test.
You need
Scale (spring for measuring force),
Wooden block,
various bits of tire (my high school and college physics teachers both spent more time telling us no to cut ourselves on steel cords than the experiment),
String
Some surface to frag on (floor, table, pavement, etc)
Basic test, drag a mass along on the same surface with each tire type, cut tire piece in half repeat (with scrap tire on top of mass), cut the remaining piece in half repeat (again scrap on top).
The various sizes of tire represent the contact patch with different inflation pressures.
You will quickly realize that contact patch has extremely little to do with friction (traction)
In order for this experiment to be valid, you'd have to apply downforce equivalent to what a real tire experiences, and you can only measure static friction.
In other words, you might as well use a real car. And real cars prove that higher pressure inflation pressure = smaller contact patch = less total traction.
Or just try telling an race driver that tire pressure doesn't affect grip because your blocks and scales said so.
