OK!
as far as the lower lamps....scrap'em. Get a driving lite set at walmart. do you home work on driving lite vs fog light. here ia picture from the inside of my bumper. Used strap metal found at home depot inthe lumber section. already has holes and is thinck enough to hold it's shape.
The I created a custom grille....you dont need to:
Since your going to put a clear plastic over it you dont need a grille, I did the front bumber several yrs before I became a ECOMODDER.
The clear plastic is very thin and strurdy. It is from a POSTER picture frme at walmart. 10bucks. Cheapest frame for posters.
I would some foam strips to fill in the top grille completely. The cover the opening on each side leaving the center bottom open.
Buy a scangauge II asap. It can give you a lot of feed back on tests.
If you do some freeway driving I'd look at going 1 size up on the tires. I 'd increase the psi today in what you have.
The underbelly pan is time consoming. Find a local muffler shop that's not busy and ask if you can look under your car. Really helps to get the big picture visually.
good luck!
test test test!!!
