Originally Posted by mcrews
so after smoothing the under belly all the way back, would a 3'' dam negate that work?
the bottom of my front lip is 7 3/4 inches to the ground. I could ratchet my springs down maybe one inch. But I had lowering springs for about 1 yr and I was ALWAYS scrapping my front lip.
What angle are you measuring?
As Metro said, no one can tell you exactly how your car will respond. The cheapest method of finding out is to just tape some cardboard on there and do some coast down tests. Underbelly pans take quite a bit of time and labor to get on, Air Dams are quick and easy. Quick and easy is the route I chose and it worked. May not be optimal, but it has been saving me money since the day I bolted it on. It was the best $13 I've spent so far...
