Old 12-26-2009, 11:10 AM   #11 (permalink)
90 day: 51.82 mpg (US)
Originally Posted by mcrews View Post
so after smoothing the under belly all the way back, would a 3'' dam negate that work?
Can't answer that definitively. But look at super-efficient vehicle designs. They all have smooth undertrays. How many also have air dams?
What angle are you measuring?
The angle between the red lines is your approach angle.
Old 12-26-2009, 07:18 PM   #12 (permalink)
wdb
lurker's apprentice
PlainJane - '12 Toyota Tacoma Base 4WD Access Cab
90 day: 20.98 mpg (US)
Air dam + undertray should be more efficient than either alone. Air dam + splitter + undertray should be more efficient still. Susceptibility to damage is probably the biggest reason you don't see more front splitters on road cars.
Old 12-26-2009, 07:55 PM   #13 (permalink)
wdb: could you elaborate or post links to supporting info?
Old 12-27-2009, 08:53 PM   #14 (permalink)
Little Blue - '98 Ford Escort ZX2 Cool
Team ZX2
90 day: 44.75 mpg (US)
Big Red - '00 Ford Excursion XLT
90 day: 15.53 mpg (US)
the bottom of my front lip is 7 3/4 inches to the ground. I could ratchet my springs down maybe one inch. But I had lowering springs for about 1 yr and I was ALWAYS scrapping my front lip.
As Metro said, no one can tell you exactly how your car will respond. The cheapest method of finding out is to just tape some cardboard on there and do some coast down tests. Underbelly pans take quite a bit of time and labor to get on, Air Dams are quick and easy. Quick and easy is the route I chose and it worked. May not be optimal, but it has been saving me money since the day I bolted it on. It was the best $13 I've spent so far...
Old 12-28-2009, 09:00 PM   #15 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
Well, not necessarily. An air dam increases the frontal area of the car, and it has to make up for the increased A with reduced Cd. If the underside of the car is ugly, it's easy to imagine that happening. If it's smooth... well, I'm not sure, but I'm inclined to believe it's best to let air under the car.
I believe this must be settled in a wind tunnel, wind tunnel simulation, or real-world coastdown testing.
Old 12-31-2009, 01:26 PM   #16 (permalink)
good spot
Originally Posted by Old Tele man View Post
...that's what I recall too. Sorta like Goldy-locks and a "...not too much; and not too little" situation..." where either side of "...just right..." isn't gonna help you.
...just wanted to make the point that "sometimes" the "good spot" (vehicle rake angle) isn't something you want to arbitrarily be playing with, unless you know what you're getting yourself in for.
EcoModder really needs a big wind tunnel so we can make these kinds of refinements.
I asked Santa,and I really tried to be a good boy,but to my knowledge,nothing came of it.
Unless Darin is holding out on us................................................ ............
Old 12-31-2009, 02:00 PM   #17 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
A little off topic, but maybe not so much........
Specificly.....what does "REALLY TRIED" look like?????
Old 12-31-2009, 02:20 PM   #18 (permalink)
look
I don't know if we have an avatar for that.
Old 12-31-2009, 04:40 PM   #19 (permalink)
...beats walking...
...a picture of your congressman? sounds like something they'd say.
CdA list Daox Aerodynamics 206 10-25-2023 06:32 PM
First ride on a (semi-)recumbent bicycle: BikeE - got a CCM Evox 120 MetroMPG Alternative Transportation 20 11-14-2011 08:29 AM
Lower your 92-95 Civic and still ride comfortably! TomO Off-Topic Tech 1 11-05-2009 11:36 AM
Joy Ride or Killjoy? SuperTrooper General Efficiency Discussion 19 08-03-2009 10:49 AM
Bike ride story. Assualt? mhmitszach Alternative Transportation 16 08-20-2008 06:49 PM
