Old 12-28-2009, 03:52 AM   #99 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by dwtaylorpdx View Post
Shouldn't tire wear be a factor as well?
For instance the 4 tires on my jeep are about 1000 dollars a set.
I know that on other all terrain tires over inflation
will grind the center away...
Dave
In all the years I've been putting too much air in everything out of sheer laziness, I've never experienced this to any measurable degree.
I have very limited experience with Bias ply highway rated tires, though, and seldom use "balloon" tires or those with an unreasonably high aspect ratio or unreasonably wide tread pattern under the same circumstances as other highway rated tires.
