Old 12-29-2009, 11:59 AM   #525 (permalink)
SVOboy
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Time for some pictures and some update.
The first is a picture from my shop manual, which kindly informed me that I was missing the water pump belt tensioner, and that's why the belt didn't work for me. Anyway, I've got the last bits of the water pump tensioner on their way here so that should be fixed up and I might actually be able to pump water (imagine that!).
This is just the car fit testing the big CRX radiator. Don't get confused that maybe the cooling system is actually installed, because that's certainly not true.
This is just to show the clearance of the intake from the radiator.
Here's the space for the A/C condenser where I'll be installing the clutch converter.
To do that I drilled some holes.
Then I jiggled the whole setup again to get things matched up right and tacked on some nuts.
After welding them up nice I just went ahead and bolted everything down. Still missing a piece or two heave and there (like some spaces for the clutch to mount up), but it'll get done soon.
Wiring in progress.
This shot was taken in complete darkness with the on camera flash. I'm just posting since I love my lens.
ID:	5224   Click image for larger version
ID:	5225   Click image for larger version
ID:	5226   Click image for larger version
ID:	5227   Click image for larger version
ID:	5229   Click image for larger version
ID:	5230   Click image for larger version
ID:	5231   Click image for larger version
ID:	5232   Click image for larger version
