Old 12-27-2009, 11:24 PM   #521 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Well, looking forward to it
Old 12-29-2009, 11:29 AM   #522 (permalink)
Little Blue - '98 Ford Escort ZX2 Cool
Team ZX2
90 day: 44.75 mpg (US)
Big Red - '00 Ford Excursion XLT
90 day: 15.53 mpg (US)
How does Wednesday, tomarow, evening sound? I can probably be there around 4:30pm.
Old 12-29-2009, 11:44 AM   #523 (permalink)
Dartmouth 2010
SVOboy's Avatar
Sounds good to me! I'm going to post an update here in a little bit. Do you know anyone to call about your friction welding idea? I'm not sure I'd know where to start, but I like that idea more...
Old 12-29-2009, 11:48 AM   #524 (permalink)
Team ZX2
No Idea who can do it around this area. I'll try to find out though...
Old 12-29-2009, 11:59 AM   #525 (permalink)
Dartmouth 2010
SVOboy's Avatar
Time for some pictures and some update.
The first is a picture from my shop manual, which kindly informed me that I was missing the water pump belt tensioner, and that's why the belt didn't work for me. Anyway, I've got the last bits of the water pump tensioner on their way here so that should be fixed up and I might actually be able to pump water (imagine that!).
This is just the car fit testing the big CRX radiator. Don't get confused that maybe the cooling system is actually installed, because that's certainly not true.
This is just to show the clearance of the intake from the radiator.
Here's the space for the A/C condenser where I'll be installing the clutch converter.
To do that I drilled some holes.
Then I jiggled the whole setup again to get things matched up right and tacked on some nuts.
After welding them up nice I just went ahead and bolted everything down. Still missing a piece or two heave and there (like some spaces for the clutch to mount up), but it'll get done soon.
Wiring in progress.
This shot was taken in complete darkness with the on camera flash. I'm just posting since I love my lens.
ID:	5224   Click image for larger version
ID:	5225   Click image for larger version
ID:	5226   Click image for larger version
ID:	5227   Click image for larger version
ID:	5229   Click image for larger version
ID:	5230   Click image for larger version
ID:	5231   Click image for larger version
ID:	5232   Click image for larger version
Old 12-29-2009, 12:00 PM   #526 (permalink)
Dartmouth 2010
SVOboy's Avatar
Thanks, I'll try to poke around too
Old 12-29-2009, 12:11 PM   #527 (permalink)
Dartmouth 2010
SVOboy's Avatar
Also, as far as wiring updates go, I have two major ones:
- I finally got power to the ECU through wiring up one of the random plugs I never thought was important
- I think I'll be able to get around any immobilizer issues by just tucking the immo under the dash with the original insight key zip-tied to it.
Both of these things are very exciting for me, and while there is still a ton of wiring left to do, I'm thinking I might be able to try to fire up the engine today.
Old 12-29-2009, 12:56 PM   #528 (permalink)
Funny's Avatar
Eco-Fit - '13 Honda Fit Base
90 day: 37.06 mpg (US)
Originally Posted by SVOboy View Post
... I'm thinking I might be able to try to fire up the engine today.
JOY!
American by right
Ecomodder by choice
Hypermiler by necessity
Old 12-29-2009, 05:22 PM   #529 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
What are you doing for an air filter and hot air intake? Or is the rag stuffed into the throttle body the final design? ;-)
Do you plan to deep-cycle your way back to NH, or drop in the big battery once you get the ICE working?
Old 12-29-2009, 05:56 PM   #530 (permalink)
Team ZX2
Any paticular tools or things I ought to bring tomarrow?
I got an old Honda Alternator you can rig up
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
Project: Zombie Insight (2000 Honda) RobertSmalls Hybrids 191 03-03-2012 06:35 PM
Project: Dream CRX SVOboy EcoModding Central 118 09-19-2011 01:42 AM
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 10:45 AM
Opinions: CRX HF, Honda Insight or Keep Suzuki Swift? dunhamjr General Efficiency Discussion 17 06-18-2008 05:14 PM
