Old 12-29-2009, 04:39 PM   #2822 (permalink)
adamj12b
EVVette - '71 Chevy Corvette Coupe
Originally Posted by xtian999 View Post
Thank you. To be sure, I am talking about adding ten equal length wires and just leaving the gate resistors on the power side of the mounting board instead of pushing them through the holes. So, when I lift the controller board up away from the power section to fix something, all the resistor leads do not have to flex. I'm just looking down the road a bit to make things more service-friendly.
Yes, That will work fine. Just get as close to the same length as you can.
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
