Hello -
My co-worker friend has a PT Cruiser, so I did some rear wheel-well analysis :
The side view is from tirerack.com. This avoids spacial distortion and makes sure that everything is horizontal. I measured the top of the PT Cruiser's wheel well (28"), and scaled the tirerack image up so that every 10 pixels = 1 inch.
Here is what you can put on the PT Cruiser :
ABS REAR SKIRTS
If your rear wheel-well matches the curve of the PT cruiser, you may be able to retro-fit it onto your car. Obviously, the complex curves might make it non-feasible, but at least there is a *chance* it will work.
PS - It ain't cheap, $400 a pair,
(1 eek for each Benjamin)
CarloSW2
