Originally Posted by pgfpro
OK, I got it running again and shes doing great!!! IM now thinking about the EGR system and trying to use a second waste gate to make it all work.
I need to make some more ground on the aero package and get it out of the way. Its just not my area of strength?
Do you have anyone that you can borrow a Hucho from? I somehow don't feel like you'll ever find it at the library... I haven't been able to.
You can test aero mods in a fish tank, by the way. You need a small bilge pump and a syringe with colored oil in it, and a scale model of your car. Small changes will not show up, but large shape alterations will be obvious. You turn the bilge pump on in front of the model, and inject the oil into the water stream where you feel you'd like to check. THe oil will separate soon after for recollection and recycling.
