Old 01-01-2010, 05:02 AM   #1 (permalink)
dennyt
in tents
dennyt's Avatar
The Adventure Wagon - '94 Subaru Loyale Wagon 4x4
Subaru
90 day: 33.43 mpg (US)
Electro-Monkey - '11 Surly Karate Monkey BMC V2S Front Hub Motor
90 day: 694.1 mpg (US)
Question Subaru Loyale - MPGuino Install
Howdy! I've been reading this forum for the last week, getting stoked on all kinds of mods. I just bought an MPGuino, it showed up in 2 days, I installed it tonight, and clearly I didn't pick the correct leads to tap into.
The unit displays just fine, but it isn't picking up VSS. I think I tapped into an unused VSS connector, but I just found on the Rostra site that I should tap into the YR coming from the speedo. Tomorrow...
Perhaps a bigger problem is that, in the custom screen, it displays 6.5 GH at idle, and the number decreases as I add engine load. Neither of these terminals showed 12V with the ignition on and the engine stopped, as in the instructions, so I just tapped into the RW on this schematic. Will switching over to the other lead to the injector fix things, or is this a peak-and-hold problem?
My car is a '94 Loyale Wagon, 5spd, non-turbo, SPFI.
Many Thanks,
-Denny
(Disclaimer - I'm a mechanical engineer, not a sparky. The vacuum gage went in tonight too, and works just fine )
Last edited by dennyt; 01-01-2010 at 05:25 PM.. Reason: not as much help needed...
