Old 01-01-2010, 05:16 PM   #538 (permalink)
SVOboy
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
She runs! She runs!
The SGII is saying the coolant temp is only 40F, which I think is wrong. I'm a little worried since I had it running for a while and I don't think the thermostat opened, but then it didn't warm up enough for the idle to drop (though if that's running off the perhaps busted wct sensor then that might be the issue, so I shut it off. It had a big vacuum leak at first and now it seems like it has a small one, but I'm not sure, it might be due to the busted sensors and such. Also, the SG isn't reading codes.
Furthermore, gotta get some wire at the store to put on a better engine ground (currently it's just hanging off the side touching a spot and it's not contacting very well, so the idle issue might be that as well. Anyway, I don't think I'll get home and get the car ready for a test drive before dark, so I'll probably have to put that off until I do some wiring and reattachments of the lights and such.
Anyway, I'm pretty happy that it seems to be working thus far.
