Old 01-02-2010, 11:34 AM   #11 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
You want to use the thinest oil that is thick enough to keep the oil pressure up, without an oil pressure gauge that is hard to tell, but I figure it's time to go to a thicker oil when my car starts to burn much more then a quart of oil between changes, I've only used 20W 50 in one car and that was because it burned a quart of oil every 300 miles.
So I would say that unless you are more the a quart low when you go to change the oil then stick with your normal oil, if you are half a quart or less low then try something thiner.
Originally Posted by Domman56 View Post
i'm wondering what is the lowest viscosity i should try on my car
