Old 01-02-2010, 11:34 AM   #11 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
You want to use the thinest oil that is thick enough to keep the oil pressure up, without an oil pressure gauge that is hard to tell, but I figure it's time to go to a thicker oil when my car starts to burn much more then a quart of oil between changes, I've only used 20W 50 in one car and that was because it burned a quart of oil every 300 miles.
So I would say that unless you are more the a quart low when you go to change the oil then stick with your normal oil, if you are half a quart or less low then try something thiner.
Originally Posted by Domman56 View Post
i'm wondering what is the lowest viscosity i should try on my car
Old 01-02-2010, 12:16 PM   #12 (permalink)
Tank - '76 Chevy El Camino Classic
90 day: 25.89 mpg (US)
Sabrina - '91 Mercedes Benz 190 E
90 day: 37.07 mpg (US)
Angel - '88 Mercedes-Benz 420SEL
Last 3: 23.01 mpg (US)
Quicksilver - '04 Mercedes-Benz CLK55 AMG Cabrio
Sweet my car never runs more than a half a quart low if that so I'll try 10w/30 on the next oil change and see how that goes
Tank:
(No actual EPA numbers for car just used F/E numbers when i first got it)
Old 01-02-2010, 01:00 PM   #13 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
If you're not burning alot between changes, it's probably the cold weight that's affecting you, and you'll burn a little bit until the engine warms up, characterized by smoking until the engine is warm.
If you're burning more than, say 1.5 or 2qt in 3-5000 miles, you're going to need a thicker warm weight, as well.
IOW - if you're only burning very little, you could still stand to go down a weight in the cold end. If you're burning alot, you'll want a thicker oil. Then again, if you're burning alot, and you intend to keep your vehicle, it's ALWAYS cheaper to fix the problem than to keep buying band-aids for it.
Fuel Economy related papers tasdrouille General Efficiency Discussion 41 03-19-2021 06:31 PM
mileage computer for a carbureted engine diesel_john Instrumentation 221 05-01-2014 10:38 PM
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
NASCAR "Advanced Fuel Economy Dodge"; NASCAR Prius model coming soon! MetroMPG The Lounge 9 07-14-2009 01:35 PM
NASCAR "Advanced Fuel Economy Dodge"; Prius branded model coming soon! MetroMPG The Lounge 0 07-08-2009 08:20 AM
