Old 01-02-2010, 05:03 PM   #11 (permalink)
Big Dave
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
With a carburated 289 the Daytona Coupe blew the doors off the GT40 with its 427 (and the Ferrari to boot) down the Mulsanne straight at Le Mans. This bespeaks aero excellence to exceed the top speed of cosiderably more powerful cars.
The rear end is beautiful, but for normal speed drivers, it would give better MPG if the cutout were perpendicular to grade. On the race car it is slanted back about 30 degrees at the top. Obviously this generated downforce (negative lift), but any time you generate lift, you generate drag.
Downforce is important as you traverse the French countryside at 300 ft/sec, but is less important at 90 ft/sec. And when you go all-oout for MPG, every little bit helps.
While you are at it, note the engine compartment vent on the front of the hood.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
