Old 01-02-2010, 05:03 PM   #11 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
With a carburated 289 the Daytona Coupe blew the doors off the GT40 with its 427 (and the Ferrari to boot) down the Mulsanne straight at Le Mans. This bespeaks aero excellence to exceed the top speed of cosiderably more powerful cars.
The rear end is beautiful, but for normal speed drivers, it would give better MPG if the cutout were perpendicular to grade. On the race car it is slanted back about 30 degrees at the top. Obviously this generated downforce (negative lift), but any time you generate lift, you generate drag.
Downforce is important as you traverse the French countryside at 300 ft/sec, but is less important at 90 ft/sec. And when you go all-oout for MPG, every little bit helps.
While you are at it, note the engine compartment vent on the front of the hood.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 01-02-2010, 06:39 PM   #12 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by thatguitarguy View Post
While yer at it, why not a big ol' 2" receiver out that beautiful backside...
Cuz, even though I'd do that, I can't afford the car.
Yes. I would put a hitch on it. Why not?
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 12:21 AM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
Recycling the whole car by keeping it on the road shovel General Efficiency Discussion 57 11-30-2009 10:30 PM
AutoSpeed Article: Low Drag Car Aerodynamics TestDrive Aerodynamics 3 03-10-2009 10:50 AM
Alt Car Expo Los Angeles 2008 cfg83 Events & Meet-ups 2 10-14-2008 06:21 PM
