Old 01-02-2010, 10:56 PM   #559 (permalink)
RobertSmalls
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
The 2000-03 Insight has an oil-to-water heat exchanger, mounted between the filter and oil pan. 04-06 models do not. You could delete the heat exchanger, which is ~3cm thick, but I bet you'd need a shorter oil filter base bolt off an 04-06, unless you can cut yours down and cut threads in it. See page 8-9 in the FSM.
