Old 01-02-2010, 08:55 PM   #551 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Man, what I pain in the butt it was to find:
Old 01-02-2010, 09:46 PM   #552 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
Originally Posted by SVOboy View Post
What the devil is a brake booster pressure sensor? My brake booster doesn't have one . Think I can just jump the wires and it'll make the code go away?
It measures vacuum at the brake booster, so the car can re-start the engine if you deplete the vacuum assist during idle stop (which I find unlikely, since idle stop doesn't work above 17mph).
Edit: it's a 3-wire device: power, gnd, signal. So the easiest way is probably to buy one and supply it with vacuum, maybe using a vacuum tee upwind of your brake booster check valve. But maybe you could put the right sized resistor between VCC and SIG to make the ECU see vacuum.
And yeah, that's the graph. Which isn't helpful because there's no vertical lines on it except at 6000rpm, and because speed limits aren't posted in KPH around here.
Old 01-02-2010, 09:55 PM   #553 (permalink)
Dartmouth 2010
SVOboy's Avatar
Yeah, troublesome graph. I'll make a better one at some point. Anyway, working now (well, eating pizza on top of the car now), so wish me luck on finishing by morning!!
Old 01-02-2010, 10:12 PM   #554 (permalink)
Dartmouth 2010
SVOboy's Avatar
Big problem:
The front cross member, even with the mount for the old front mount completely hacked off, contacts the oil filter by a few MM. Meaning, running the engine like this would just be bashing the oil filter against the front crossmember until something breaks.
Ideas?
Old 01-02-2010, 10:19 PM   #555 (permalink)
Little Blue - '98 Ford Escort ZX2 Cool
Team ZX2
90 day: 44.75 mpg (US)
Big Red - '00 Ford Excursion XLT
90 day: 15.53 mpg (US)
Make a new cross member with a cut out?
Old 01-02-2010, 10:21 PM   #556 (permalink)
Dartmouth 2010
SVOboy's Avatar
That's not something I have time for right now. Currently, darin is suggesting cutting out the section and welding a step in for clearance, and I'm thinking, I could just take a hammer to it. Sound bad?
Old 01-02-2010, 10:33 PM   #557 (permalink)
Dartmouth 2010
SVOboy's Avatar
I decided to side with darin that without the front mount the front xmember isn't really worth much so I just bashed in a 2x2" area about 1/2" and it's fine now
Old 01-02-2010, 10:45 PM   #558 (permalink)
90 day: 57.73 mpg (US)
Quick 'n' dirty. Not enough time to find a smaller filter or fabricate an inset section.
Old 01-02-2010, 10:56 PM   #559 (permalink)
Left Lane Ecodriver
The 2000-03 Insight has an oil-to-water heat exchanger, mounted between the filter and oil pan. 04-06 models do not. You could delete the heat exchanger, which is ~3cm thick, but I bet you'd need a shorter oil filter base bolt off an 04-06, unless you can cut yours down and cut threads in it. See page 8-9 in the FSM.
Old 01-02-2010, 10:56 PM   #560 (permalink)
Team ZX2
As I was showering, I was thinking there has to be some remote mount system out there that would bolt up...maybe another time.
Mini Sledge to the rescue!
Are you planing on leaving tomarrow?
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 12:59 PM
Project: Zombie Insight (2000 Honda) RobertSmalls Hybrids 191 03-03-2012 07:35 PM
Project: Dream CRX SVOboy EcoModding Central 118 09-19-2011 02:42 AM
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 11:45 AM
Opinions: CRX HF, Honda Insight or Keep Suzuki Swift? dunhamjr General Efficiency Discussion 17 06-18-2008 06:14 PM
