Old 01-03-2010, 10:52 AM   #226 (permalink)
jackbauer
jackbauer's Avatar
http://www.evcomponents.com/ProductD...uctCode=PFC-50
"This charger is non-isolated. The negative terminal of the battery is connected to the negative terminal of a rectifier bridge with the AC terminals connected to the incoming line through a 50 amp breaker"
That make me feel a lot better about the non isolated design.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
The Following User Says Thank You to jackbauer For This Useful Post:
dave77 (01-08-2010)
