Old 12-23-2009, 09:29 AM   #221 (permalink)
jackbauer's Avatar
....the saga continues.......just gotta stay ahead of the Libyans
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
Old 12-26-2009, 01:51 PM   #222 (permalink)
jackbauer's Avatar
Christmas entertainment
www.evbmw.com
The Following User Says Thank You to jackbauer For This Useful Post:
dave77 (01-08-2010)
Old 12-29-2009, 08:23 AM   #223 (permalink)
jackbauer's Avatar
I decided to have a rethink on the voltage and current sensing. First the current. I looked at the popular lem hass series of transducers but didnt like the limited output of only 625mv for full scale. Noise would be an issue and the code would need to be altered beyond my ability. Some searching revealed the Honeywell CSNF651 senseor:
http://radionics.rs-online.com/web/s...duct&R=6673465
This simple little guy outputs 50mA at 100A primary. So for a 50amp sense setup it just needs a 200R precision resistor to turn 25ma (50A) into a 5v signal and is of course variable and fully isolated.
Next the voltage. I had looked at linear optos but the only ones i could source were messy setups. Came upon the LEM LV25-p voltage transducer:
http://radionics.rs-online.com/web/s...duct&R=0286361
Similar to the current sensor it converts primary current to secondary current with full isolation. Nominal primary current of 10ma results in a secondary current of 25ma. So a primary resistor of 10k would result for a nominal voltage of 100v and a precision 200R secondary resistor converts this inot a 5v o/p. the only real disadvantage here is that the primary resistor must be chosen to be reasonably close to the nominal pack voltage being charged. 96V in my case so I use 100v for easy maths. This does bring a little added complexity but the resistor could be mounted in a sil socket for easy changes.
These two mods , I believe , solve the isolation issue. The control board gnd can then be tied to mains earth for complete safety. The only unisolated parts being inside an earthed metal enclosure makes it no more hazardous than a pc power supply. Granted the battery terminals are still "hot" but good practice would be to have the terminals fully insulated in any case. The charger is probably close to $300 with these changes but still exteremy cheap and versatile.
Soon as Radionics reopen next week (year?) i'll get the bits in and report on progress. Any thoughts?
www.evbmw.com
dave77 (01-08-2010)
Old 12-30-2009, 07:29 AM   #224 (permalink)
nice
when do you begin selling them
count me for 1
thanks
Old 12-31-2009, 11:20 AM   #225 (permalink)
jackbauer's Avatar
Had a little play with mikrobasic and have the board outputting charge voltage and current via rs232 at 9600 baud. Its a nice language easy to get to grips with. Now all i need is a pc frontend. hint hint
Happy new year all
www.evbmw.com
Old 01-03-2010, 10:52 AM   #226 (permalink)
jackbauer's Avatar
http://www.evcomponents.com/ProductD...uctCode=PFC-50
"This charger is non-isolated. The negative terminal of the battery is connected to the negative terminal of a rectifier bridge with the AC terminals connected to the incoming line through a 50 amp breaker"
That make me feel a lot better about the non isolated design.
www.evbmw.com
dave77 (01-08-2010)
Old 01-03-2010, 11:30 AM   #227 (permalink)
Out of my mind, back in 5
Yeah, I'm quite certain that 50A breaker is rated a lot higher than me...
Old 01-03-2010, 11:40 AM   #228 (permalink)
AC-DC enthusiast
mrbigh's Avatar
Dual-PWR PHEV - '04 Toyota Prius
Kopper - '79 Bradley Bradley GT-II
Jack, I own and use the PFC40HM version of the same charger/DC-DC converter from Manzanita Micro since the last 4 years and it works flawlessly.
No isolation technical issues at all. It is a buck and boost converter, serving from 85 to 244 AC input to 15to 360 VDC (never tested higer voltage) at a rated 40+Amps from a 30 Amp service line. IGBTs final stage under variable forced cooling.
With it I recharge in a daily basis the NiMH of my Prius PHEV.
Prius Absolutum Dominium . ..........KOPPER
PHEV conversion since Dec 2006.. . .... .Future EV
. . . . . . . .CALCars # 27. . . . . . . . . . ..on the works now !!
The Following User Says Thank You to mrbigh For This Useful Post:
dave77 (01-08-2010)
Old 01-07-2010, 02:23 PM   #229 (permalink)
jackbauer's Avatar
Small update. the current and voltage sensors are now up and running. quite accurate and linear. control board is now fully isolated from the power section.
www.evbmw.com
dave77 (01-08-2010)
Old 01-08-2010, 08:20 AM   #230 (permalink)
jackbauer's Avatar
quick vid of the first isolated run:
www.evbmw.com
dave77 (01-08-2010)
ev charger
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 01:21 AM
Any interest in developing an open source fuel economy gauge/computer? MetroMPG OpenGauge / MPGuino FE computer 182 06-25-2010 08:00 AM
Open source PCB design dcb OpenGauge / MPGuino FE computer 39 04-25-2010 10:18 PM
Open Source electric conversion information bennelson Fossil Fuel Free 8 02-14-2009 12:23 PM
Open Source LEV Controller FrankG Alternative Transportation 1 03-24-2008 04:10 AM
