Old 01-04-2010, 01:23 PM   #392 (permalink)
3-Wheeler
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Originally Posted by Nerys View Post
...ie if we were talking about 2 or 3 % sure any small variation TP and Wind would have a statistically relevant impact...
Hi Nerys,
For what it's worth...
On the Insight, the TPS is not as sensitive as the MPH indicator.
I have not kept a real close eye on this, but have noticed in warmer weather, and with the TPS at 17, the mph can vary I'd guess about 3 mph.
That is to say, watching the MPH indicator gives a better hold on speed than watching the TPS reading on the ScanGauge.
My tach is not nearly as sensitive as the MPH reading.
______________________________________________
I suppose one could put an externally mounted variable pot on the throttle body shaft and make that work in conjunction with an ohm meter reading...
Jim.
