Old 01-07-2010, 06:26 PM   #45 (permalink)
dremd
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
You know it's cold when your utility company has rolling black outs due to cold weather.
You know it's cold when you spend 2 days covering + heating Orange trees.
You know it's cold out when polyester gelcoat hardens like a rock without ever opening the can.
You know it's cold out when lacquer flows like Molasses.
You know it's cold out when your Whatt's Up Indicates that your car battery has an effective capacity of 10 Amp hours and battery only has 4 volts left after test. Well, Ok that battery was toast anyways.
You know it's cold when even though you are an EcoModder you consider going out and starting your TDI just to see if it will start.
You know it's cold out when you are running strait Diesel for the second tank this year.
Originally Posted by NiHaoMike View Post
...a WRT54G V3 runs stable at its maximum power setting of 251mW... (Going below freezing will do that. Still need to up the voltage to get a good signal, though.)
Mine run stable at 251 No problem, the receive sensitivity goes in the toilet . . .
But then again I do have North bridge heat sinks on mine though.
How do you increase the voltage on the radios?
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
