Old 01-08-2010, 10:29 AM   #2 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
What you're describing isn't pulse and glide - gliding happens in neutral, usually with the engine off, though some do it with the engine on.
Your options, depending on what traffic will allow, in order of effectiveness are:
- pulse up, glide down
- Drive with load (DWL): adjust the throttle to maintain a target MPG value on the instant display. Meaning, progressively easing the throttle and bleeding speed on the way up & adding throttle and regaining speed on the downside.
- Constant throttle: less efficient than DWL, but you also lose less speed on the incline
- "Cruise control": what most people & cruise controls usually do, which is feed more and more throttle on the way up to maintain speed, and back off the throttle on the descent to hold speed.
