Old 01-08-2010, 04:57 PM   #2 (permalink)
aerohead
noise
Originally Posted by mjboks View Post
I made and installed a grill block last month. First created a cardboard cutout that fit the grill. Then traced the pattern onto Lexan and cut it out. I cut and oval around the front emblem since that part sticks out from the rest of the grill. Plus between the Toyota "T" emblem, it's open so a bit of air can get through. I drilled pairs of holes and zip tied the block to the grill. So it can be removed with a knife if needed. The lower grill is also blocked with 3 zip ties. The two triangles on either side are not open, just aesthetic.
So far, it's hard to tell what type of aero or efficiency affect it may have but I'm sure it can't hurt. My daily commute is only 8-9 miles each way so the engine barely warms up, but it's quicker now with the grill block.
I'm certain that you've cut drag.The problem is that your gains are being masked by the signal-to-noise ratio of the winter temps and all it does to lower your mpg.
22 miles of continuous 50-mph driving is required just to warm a car up completely,to whatever it's ambient equilibrium temp is.
Your short commute is killing your mpg.
As temps build in the spring,be ready to open your block a bit so as not to cook anything important under the hood.
The block looks good!
