Old 01-09-2010, 12:28 PM   #79 (permalink)
MetroMPG
90 day: 57.73 mpg (US)
KB: maybe you've arleady seen this.... but bondo's is the Swiss army knife of truck caps! It opens like a hatchback, can be converted into a conventional square camper cap with the addition of side & rear curtains, and the upper hatch can be removed entirely for transporting tall objects. See this thread for photos: http://ecomodder.com/forum/showthrea...d-cap-583.html
Also, regarding flow effects, you may be interested to view on-road tuft testing of a tapered bed cap: http://ecomodder.com/forum/showthrea...per-11522.html . That thread somewhat addresses the issue of the flow transition from the side to upper surfaces (in that case a sharp transition, more likely to trip flow, yet it still appears to work well - though the upper angle is shallower than most).
